How to get the busy time of CTS line ?
Hi..everybody..!!
I communicate with instrument over RS485 by using LabVIEW 7 on Window XP. The instrument makes the bus busy when it works by sending the CTS is not ready. The busy of CTS line also depended on the integration time.
I want to measure the time that CTS is busy. Now I use the property node of serial to read the status of CTS (false or true). I don't know if there is some function that I could take this busy time ?
The point is I don't want to add so much step code for this time measurement into my program because I want to find out the time efficiency of LabVIEW code. (eg. how much time that I need more for LabVIEW program itself).
Thanks in advance for any help..!!
(3,488 Views)
you just have to include a property node for serial communication into your program. One property is the CTS line. Then you have just measure the time if the CTS-line answear is not 1 or asserted. So you can get the time.
Time measuring can work with tick count(ms). You just have to substract it from beginning value.
Regards
R.T.
Technical Support
NI Germany
(3,488 Views)
Hi..R.T,
Thanks for your solution. I try to do in your way by create the small program to simulate the CTS status (as in attach files). It works very well. but actually when I use in the real program which has the other sequencial stack in the while loop. it is not work any more. !! I don't know if I make some mistake
(3,488 Views)
out of your VI check CTS unassert-time, I could not give you any problem solution.
You should debug your program to check the true order of the sequential stacks.
I hope you get rid of your problem so far.
Regards
R.T.
NI Germany
(3,488 Views)
