How to get touch with PC through my NAT 9914 ?
hello,after sevral weeks hard-working ,I can write and read the NAT 9914 register.and I verify it according to the code "test.c" on A110.pdf.
I'm here to ask one question about exchanging message with PC(controller).
On my PCB board ,I have a GPIB interface and RS232 port.I had wanted to connect the GPIB interface to the PCI-GPIB card which I got one from one project I worked on,and in this system ,the PCB board(nat9914 board) acts as a device, and the PC acts as a controller, in which I can write a machine interface with C# or LIBVIEW.
return to my PCB board,by finishing the initialization of the NAT9914 and sending  to and receving data from 9914,what else steps i must do ?
I'm confused when is the right time to get the PCI-GPIB card to my nat9914 board.
any advice will be great,looking for all of your reply.
thanks
CM
edit on June 8th.2011
(3,140 Views)
I also verify it according to the code "test. C" on A110.
Why do some pass and others fail?
(2,521 Views)
