How to implement bit function
Dear All,
I am trying to port some old HP Calculator routines across to vb.net.
On the old HP calculator there is a function bit(bit, word), eg  if bit(3, x) = 1
I this example the function just checks if bit 3 is 0 or 1 in a word contained in x.
Is there a way to do the same function under vb.net?
Mark
(3,321 Views)
what you need maight be:
function bit(b,w)
bit= w and 2^b
end function
For transferring HP programs with Output/Enter commands, you might also
consider LabTab as a convenient API.
You can experiment Output/Enter with it at: www.labtab.com/ni_gpib0
url.
You need a device at GPIB address 1 and an NI GPIB board declared as
GPIB0.
Regards
FG
FG
(3,283 Views)
