How to initialize IEEE 488 for Hp4145B with labview 8.5
Hi,everybody!
I need some help for mw work. Now i'm working with Hp4145B, semiconductor Parameter Analyzer which use GPIB-IEEE488 as the connector and LABview 8.5. But the problem is i can't initialize the GPIB-IEEE 488. Error number 0 always shown,everytime i ran the program. how to initialize it?
thanx for your attention
(4,553 Views)
The driver is very old and unsupported but you could specify exactly which function is throwing the error. Also, what is the make and model of the GPIB controller you are using?
(4,535 Views)
thanx for the response.
I'm sorry, but i'm not  quite understand about your question. what do you mean with it?
(4,522 Views)
I would have assumed that you used Help> Find instrument Drivers instead of writing your own code. If you did, what function in the downloaded code is giving the error? If you didn't, why not? At least start with it.
You say your program gives an error but you did not attach your program.
(4,516 Views)
and to be sure, error number 0 normally means no error.
So why do you think there is an errror?
greetings from the Netherlands
(4,509 Views)
FYI, the links below should help, should you want to do any future driver development.  These are the tools NI currently provides to aid customer driver development efforts.
Instrument Driver Development Tools and Resources
http://www.ni.com/devzone/idnet/development.htm
NI LabVIEW Instrument Driver Development Studio 1.1
https://decibel.ni.com/content/docs/DOC-20135
Shawn S. | NIC
Instrument Driver/IVI PSE
(4,499 Views)
