How to install NI-Device Plus to target
How do I install the NI-Device Plus plug-ins on my Windows XP based target machine? I cannot find any documentation telling me what are the distributable modules and how to install them (or do I have to use the original setup from the development CD and install it on every target machine?).
Message 1 of 8
(4,228 Views)
Hi FreddyBZ,
NI-Device Plus is older software and due to its age documentation for it can be rather hard to find.  You can perform the full installation on your targets but there is a minimum set of dlls that need to be installed on the target machines for your application to run correctly.   At this time I have not been successful in finding the required dll list and would suggest performing a full install of the dlls to ensure your application works properly.
Andy L.
Message 2 of 8
(4,201 Views)
Thanks. It seems I'll have to monitor file and registry changes while installing the runtime files. 😞
Message 3 of 8
(4,197 Views)
I checked into it and you will need to install NI-Device on each target machine for your application to work properly.  To assist with the instillation I have attached a knowledgebase article that explains how to create a script to help automate the instillation process.
http://digital.ni.com/public.nsf/allkb/878FC4C374013ADF8625733D00688F67
Andy L.
Message 4 of 8
(4,150 Views)
Thanks Andy!
I may still look into monitoring file installations and registry modifications, to create a minimal set of updates for in the field field upgrades. But your info gives me a reasonable solution to fallback on.
Message 5 of 8
(4,144 Views)
For curiosity more than anything, what bus plugins are you using with NI-Device Plus?
Message 6 of 8
(4,122 Views)
I don't even know yet how the plug-ins and/or other software modules are organized (I'm just starting on this project). If by plug-ins you mean GPIB, ethernet, RS232, or USB, than I'm planning to use ethernet and GPIB for sure, and maybe also USB.
Message 7 of 8
(4,114 Views)
Yes. I was talking about GPIB, USB, and/or Ethernet. Thanks. I hope it all works out for you. Good luck!
Message 8 of 8
(4,105 Views)
