How to integrate a signal with respect to time
Hi, I am using an oscilloscope to get the current of a circuit I(t) and I need the charge Q(t) where I(t)=dQ(t)/dt.
now I am having a vector of I(t) of 1000 rows, I would like to have the primitive of that with respect to time as a 1000 rows vector.  Here is attached the VI iam using but I am getting a two elements as a result of the integration.
Do you have any idea how shoul I correct it?
Thanks in advance.
(4,532 Views)
You are passing the dt of each capture to the integrate function. You want to pass the channel data. I have no idea which channel the current is. You'll have to use the index array function on the 2D array you've created from both.
(4,525 Views)
The channel 1 is the current, I want to integrate with respect to time. the integration that I made is an attempt I am not sure if it should be like that.
(4,521 Views)
Then index element 0 of the 2D array and pass it to the integrate function.
(4,517 Views)
How can I do that?
(4,514 Views)
As I said, use the Index Array function.
You should really take one of the LabVIEW tutorials.
(4,508 Views)
