How to interact Motor Controller with Load cell via LabVIEW
Dear all,
I am kindly asking you for help to programming my Test setup which is indicated below:
I have a loadcell, motor and a motor controller, i have all the motor controller labview drivers!
The question is: i dont know how to use these labview drivers and how to interact the motor controller with the loadcell.
Please have a look at the summary of the working principle for this setup below:
While the linear stage  is running on a single axis via the motor controller ,  the linear stage touches the loadcell and  it is starting to make compression on load cell and after a specific, predefined Force, (for example 10 Newton) on the loadcell, i want to stop the motor so it does not go further, and then start to moving the linear stage at the negative direction now it will make a tensile strength on the load cell then again i will want to stop the motor controller when the loadcell reaches the predefined force (for example 10 Newton)
I read all the data sheets but it is not indicated that how to use these labview drivers, For example: How to turn the load cell’s output to an input to the motor controller? should i use “acceleration”and “set velocity” drivers next to each other? How to connect them? Doyou know any similar or exact codes? Which product should i use? (SignalExpress? Regular Labview? Control&Simulation? etc..)
Please have a look at my brand new equipments below:
Motor Controller= Newport SMC100CC Single-axis DC motor controller/driver
Motor Linear Stage= Newport MFA-CC Miniature Linear Stage DC motor
DAQ= NI USB-6343, X Series Data Acquisition
Loadcell = Transducer Techniques, GSO-100 (Tension&Compression)
Loadcell Signal Conditioner = Transducer Techniques STAND ALONE / BENCH TOP, 0 to ±10VDC OUTPUT
Thank you for reading,
Have a nice day,
Best Regards,
Kindly wisher.
(3,695 Views)
If you are not experienced in LabVIEW please follow a real course or let somebody else implement the system.
Signal express I would not use but regular LV is more than sufficient.
greetings from the Netherlands
(3,686 Views)
Hello Hope you are doing great!
To start I would recommend taking a look at the IVI drivers for the device you want to control.
Please take a look at this so you get a better Idea of how to use instruments drivers and what instrument drivers are.
Definetely I would go with LabVIEW with the motion control toolkit, as you need to program and communicate with third party instruments.
Luis A.
(3,655 Views)
