How to interact with a straightpoint load cell in LabVIEW?
I have a Straight Point Radiolink plus load cell. I need help with creating a VI to gather data from the load cell and to be able to wake and put the cell to sleep. It is connected to my PC via a RAD24 Radio controller that plugs into a USB port. How could I create such a VI?
(5,771 Views)
Hey Mr._Cuddlesworth,
If you open NI MAX, can you see your device underneath the "My System -> Devices and Interfaces" section?
Ty Prather
Technical Marketing Specialist
(5,699 Views)
No, it does not show up anywhere.
(5,692 Views)
It doesn't show up even in Windows Device Manager? If it does, what driver is the USB connection using? For it to be seen in MAX, the driver has to be USBTMC, RS232, or a driver you create from scratch with the VISA Wizard. That does not mean you can't use it with LabVIEW. You would use the driver provided by the vendor.
(5,674 Views)
This is all the information I could fin on the drivers. I did find it in device manager.
(5,628 Views)
HID - https://en.m.wikipedia.org/wiki/USB_human_interface_device_class
For LabVIEW and USB, see a great series of articles written by the user Intaris. The first is at http://forums.ni.com/t5/LabVIEW/Nugget-1-of-n-GEtting-started-with-USB-communication-via-VISA/m-p/74...
You'll need a lot more information from the vendor.
(5,614 Views)
