How to interface a fuel level sensor on USB/serial port to indicate the level?
Accepted by topic author MGabor
Hi Gabor,
Could you give some information about your sensor and USB converter IC? (Vendor, Type, DataSheet)
I think you cannot send and receive data at the same time on 1 wire (1 pair of wire) at the same time neither serial communiation nor USB protocol.
Firstly, if you connected your device to USB port, it does not neccessarly follows that you have USB-RAW communication. If you used some serial-USB converter from Dallas and you installed the software for it, you will get serial data on the PC with connectong to the virtual COM port provided by the software. In this case there is a USB encapsulation within a serial data packet.
Secondly, you have to use USB-RAW communication when you have a (active) device which has some logic within USB stack implemented. Serial-USB ICs are usually not working in this way.
So, could you provide some information about your equipment?
Peter
Peter Vago
Message 11 of 19
(2,384 Views)
Sorry for that, but i can give u these infos only tomorrow, because the sensor is not here by me. As soon as i can i ll post the infos. Thank you for your help!
Regards
Gabor M.
CLA
Message 12 of 19
(2,382 Views)
Hello!
You was right. The equipment is connencted to USB but the PC "see" it as a serial port, named COM1. I executed a serial communication example VI (resource name COM1), but there was no answer in the read string window. What can be the problem?
Thanks for your answer!
Gabor M.
CLA
Message 13 of 19
(2,372 Views)
Sorry for posting so much, but the equipment is working. I can read out a string for the device, the last question (i hope:) ) is that, the device gives the following string:
\FC\03:DAT1:\s\s\s\s2[mm]\00\04
My question is, how can i indicate the 21st character of this string?
Thank you for the helps!
Regards, Gabor
Gabor M.
CLA
Message 14 of 19
(2,369 Views)
Everything is done, convertion too, so thank you very much all for your help!
Gabor
Gabor M.
CLA
Message 15 of 19
(2,366 Views)
Hi Gabor,
I just would like to close this topic with the solution, because somebody probably will find our discussion and will be wondering about it.
When you executed the serial read VI and you could not see the values, probably you had to set the proper parameters of the serail communication (Baud Rate, Stop bit, Handshake).
For getting the 21st character from a string you can use the String Subset VI, with wiring the constant 20 as offset and constant 1 as length into it. Am I right?
If you have further question or information, just post it please.
Peter
Peter Vago
Message 16 of 19
(2,362 Views)
Yes you are right, with the solution of the problem. Once again thank you for your answers!
Regards
Gabor
Gabor M.
CLA
Message 17 of 19
(2,359 Views)
I have working sand level sensor. Sensor that is Rechner sensor have a 1.3 m long capacitance probe. Have CAN inside. 8 pins. supply +24 voltage. And I have connected point to point with PCAN-USB adapter from PEAK company. Then connected with my PC. ANd then I installed PCAN-view software. And its not working.?
Thanks a lot
Message 18 of 19
(2,237 Views)
The sensor, adapter, and software are not NI products. Why have you hijacked this old thread? You should find a more appropriate forum.
Message 19 of 19
(2,232 Views)
