How to measure the Noise Figure(NF),IIP3,Stability using Agilent N5230A,PNA-L network analyzer
Dear Sir,
              I have designed the low noise amplifier, we have AGILENT NETWORK ANALYZER with  N5230A PNA-L network analyzer. We don't have the user guide for the above said instrument. Can you guide me any one, how to measure the noise figure , third order input intercept point (IIP3) , third order output intercept point, and stability of the low noise amplifier using N5230A , PNA-L AGILENT NETWORK ANALYZER.If anybody knows help document links for Noise Figure, IIP3,OIP3, stability of low noise amplifier measuring using PNA-L, N5230A network anylyzer, can you show me.
(5,798 Views)
@suresh_babu wrote:
Dear Sir,
manual for Agilent network analyzer can be found at agilent's website
Your question has nothing to do with using NI equipment or software.
(5,790 Views)
Not only not a Labview question, but the PNA is not the right instrument for measuring Noise Figure.
(5,783 Views)
Also you don't measure an Amps stability. You measure the s-parameters and calculate the stability from the S-pars and the device, load and source matches.
(5,779 Views)
Dear Sir,
             All are telling that using N5230A,PNA-L network analyzer ,it is not possible to measure the Noise figure. O.k, how can we measure the third order intercept point (IIP3).
(5,774 Views)
If the analyzer has tuned receiver mode setup for one of the 3rd order product tone to be power swept. Then look for the bend in the power curve. Again though this post is for Labview issues not Agilent test questions. I suggest you use the Agilent call center to get your question answered.
(5,763 Views)
