How to open case of GPIB-USB-HS+
Hi all,
Following my recent experience with the serial EEPROM in my GPIB-USB-HS losing its memory, I thought I should open up my GPIB-USB-HS+ and take an image of its EEPROM.
Unfortunately I've failed at the "first base" - undo two Philips screws, and then what? Case doesn't want to open and I don't wish to break it! I thought there might be another screw under of the labels, but if there is, I can't find it by the usual trick of pressing on the label which normally reveals the location of screws or screw holes.
Does anyone know how to get inside these?
David
Message 1 of 1
(1,037 Views)
