How to operate a fiber optic switch with seria port?
That screen shot doesn't help at all.  Post your VI.
Message 11 of 12
(2,444 Views)
For each command, you must append a CR/LF as the manual states. Your front panel does not show you doing this. If the string control is set for '\' Codes Display, you use \r\n. You can also use the concatenate string function on the block diagram to append EOL from the string palette.
I don't understand your comment on 'schematic'. There are no schematics associated with LabVIEW.
Message 12 of 12
(2,436 Views)
