Hi Paul,
There are a couple of instrument drivers available on the
instrument driver network for the Keithley 2000.
You can use the instrument driver functions or use the source code to determine what commands are sent. For example, The LabVIEW plug and play driver has a VI for multi read, which is what you are looking for.
Hope this helps out.
DiegoF
National Instruments.
Message Edited by Molly K on 02-18-2005 11:06 PM
