How to program with VC++ ?
I have a GPIB-USB-HS  card now. I want to know how can I program it with VC++. What's the relationship SCPI and VISA, will we use the SCPI commands when we write a program?  I will be very grateful if you offer me some documents about the programming issue!
(3,294 Views)
I would start here if I were you: http://zone.ni.com/devzone/cda/tut/p/id/4359
and here: http://en.wikipedia.org/wiki/Standard_Commands_for_Programmable_Instruments
As for examples, these get installed when you install NI-VISA and/or NI-488.2.
You should also look in IDNET to see if there is an existing instrument driver for your instrument: https://www.ni.com/en/support/downloads/instrument-drivers.html
(3,283 Views)
