How to "publish" IVI class drivers in MAX to link a specific driver to a given class driver ?
Hello All
I am developping drivers for a family of instruments for whitch no IVI drivers are available.
I would like to manage these instruments like any other IVI instruments in my test system
I created a New Class IVI driver with the "Create IVI Custom Class Driver" Wizard of Labwindows/CVI, for my instrument family
Then I created a New Specific IVI driver with the "Create IVI Specific Driver"  Wizard, for one of the instruments of my family.
In MAX I created a Instrument Driver Software Module for my specific driver.
In the published APIs tab I can't add the API of my new Class Driver.
Question : How to "publish" IVI class drivers  to link a specific driver to a given class driver ?
I use MAX 4.5 and CVI 8.5
Thank you for your help
(3,845 Views)
Accepted by topic author nveron
Hello Nveron,
        It looks like you will need to manually update the IVI Configuration Store xml file to do two things:
-Add your Custom Class as one of the published APIs
        <IviPublishedAPI id="p678">
            <Name>IviCustom</Name>
            <MajorVersion>1</MajorVersion>
            <MinorVersion>0</MinorVersion>
            <Type>IVI-C</Type>
        </IviPublishedAPI>
-Add the published APIs to the software module
 <PublishedAPIs>
                <IviPublishedAPI idref="p3"/>
                <IviPublishedAPI idref="p8"/>
                <IviPublishedAPI idref="p678"/>
 </PublishedAPIs>
I just chose p678 as the idref to keep it from conflicting with the other existing idrefs.
Let us know how it goes,
NathanT
(3,829 Views)
Thank you Nathan for your suggestion, it works!
Effectively using  a high and unused ref number avoids conflicts.
Now when I call the functions of my class driver, the system switches to the specific drivers functions.
Cheers
NVeron
(3,777 Views)
Hello NVeron,
       I am glad that it worked well for you.  Thank you for letting me know.
NathanT
(3,750 Views)
