How to save a 2d data to a file having two variables.
I need help to save a a data into file . The 2D data contain two variables. I need to see side by side the values. What I have to do please give some clue
Message 1 of 9
(4,069 Views)
Since you have been over at the LabVIEW forum, get familiar with LabVIEW by using it and doing the tutorials and looking at the examples.
Write to Spreadsheet can write 2D array.
Message 2 of 9
(4,064 Views)
default LabVIEW uses rows, use transpose array to get columns
greetings from the Netherlands
Message 3 of 9
(4,054 Views)
thank you for your reply, But it will come as a table if I use transpose array, and I have to give my array values directly to the transpose please reply
Message 4 of 9
(4,048 Views)
use build array to get a one dimensional array
check concatenate on that function if you want to add an array to another one when you don't want to increase the dimension of the array
Message 5 of 9
(4,040 Views)
Thank you for your solution.But can you solve that hile loop problem which i posted in forum, I didn't get any idea for that
Message 6 of 9
(4,039 Views)
You were told to attach your VI by Dennis K.
Message 7 of 9
(4,034 Views)
I had attached it please reply
Message 8 of 9
(4,027 Views)
You have posted multiple times about this topic.
The anwers are in the other thread. STAY THERE.
Message 9 of 9
(4,025 Views)
