06-07-2017 11:37 AM
Greetings,
I am trying to use a PAR 273 potentiostat to perform and record cyclic voltammetry via GPIB/USB interface with a computer. Using labview's I/O feature I can control the potentiostat with the commands provided in the manual. I have determined how to run a CV, but I can not figure out how to have the device record the data. Can anybody with experience in using PAR potentiostats advise me as to how to save data points? I read in the manual that the potentiostat can save data to a curve in its internal memory and then dump the data to the computer, but I have not been able to save the CV data to the curve. Thank you!
06-07-2017 12:48 PM
It discusses how to save the Curves in section 2.3 of the, Model 273A Potentiostat/Galvanostat Command Set Handbook located at: http://www.ameteksi.com/-/media/ameteksi/download_links/documentations/supportcenter/princetonapplie...
06-07-2017 01:12 PM
Minions,
Thank you for your reply. I've read over this section of the command set handbook before, and I understand how to designate the desired curve in which the data should be stored. However, I've been unsuccessful at determining the commands to specifically save the CV experiment to that designated curve. If you have experience with this, could you explain the steps you took to save and access your data?
