How to save data waveform TDS7000 via GPIB
I was having problems trying to save data waveforms from scope TDS7000 connected by GPIB and under CVI program. I installed the scope driver and after using the function "tkdpo7k_FetchWaveformToFile", the result was only one line of data (one point).
Any suggestion welcome!
(4,310 Views)
Hello Trosber,
        Can you please confirm that you are using the NI-Certified tkdpo7k IVI Driver?  Also, do the examples run correctly?  Please go through the Instrument Driver Troubleshooting Guide and post the results.
Cheers,
NathanT
(4,299 Views)
Hello Trosber,
        I installed the NI-Certified tkdpo7k IVI Specific Driver and could not find a function with the name "tkdpo7k_FetchWaveformToFile". If you are using the NI-Certified driver, I recommend that you code the File I/O seperate from the waveform acquisition.
-NathanT
Message Edited by NathanT on 04-20-2010 10:48 AM
(4,295 Views)
Thanks Nathan for your quick answer. I am using another driver, tkdpo7k but manufactured by Tektronix (not supported by NI). I have already programmed functions for the TDS3054B scope without any issue, but saving is not well solved (I think).
Where could I find any examples of saving waveforms into a PC, using this type of driver?
Thanks again for your help.
(4,266 Views)
Hello trosber,
        The first place to look for examples is Example Finder (Help >> Find Examples...).  It contains a couple of File I/O examples that you might find useful.  If none of those help, please consult the NI Developer Zone.
Cheers,
NathanT
(4,256 Views)
