How to search supported models??
Hi, i am using IVIConfigurationServer finctions...
I want to search if an specific instruments model is supported by any of the software modules that i have registred in my configuration Store.
It´s that possible????
(3,436 Views)
Hello geodo,
       That is certainly possible.  Since the IVIConfigurationStore file is an XML file, you could devise your own way of parsing it if there is not a way to accomplish what you need through the ConfigurationServer functions.  It looks like you could probably use:
ViStatus _VI_FUNC IviConfig_GetSoftwareModulePropertyViString (IviSoftwareModuleHandle SoftwareModuleHandle,ViInt32 PropertyID,ViInt32 BufferSize,ViChar Value[]);
with a PropertyID of:
IVICONFIG_VAL_SW_MODULE_SUPPORTED_INSTR_MODELS
That is defined at the top of the header file (IviConfigServer.h) found at C:\Program Files\IVI Foundation\IVI\Include
I will leave it up to you to determine how you would like to iterate through the software modules.
Let us know how it goes,
NathanT
(3,421 Views)
Thanks Nathan
I get to search for a model
IIviSoftwareModulePtr sm(
__uuidof(IviSoftwareModule));
total=cs->SoftwareModules->Count;
printf("Hay %d SM\n",total);
//printf("hola");
for (indice=1;indice<=total;indice++)
sm=cs->SoftwareModules->Item[indice];
if(strstr(_bstr_t(sm->SupportedInstrumentModels),"E8251A")>0)
printf("\nSiii ");
printf("\n");
printf(_bstr_t(sm->SupportedInstrumentModels));
Its run correctly
(3,392 Views)
