How to set up HR4000
Excuse me for I just can't read out where to work out.
Message 11 of 15
(1,537 Views)
due to an error the output of the read waveform was not conncted to the output indicator, resulting in an empty wavefoorm.
That error should be repaired last week.
So either download the driver again or repair the missing wire.
greetings from the Netherlands
Message 12 of 15
(1,536 Views)
Thank you for all. I should be bugged with it..too crap
Message 13 of 15
(1,532 Views)
Another question that if it is a direct way to add integration time in the module for example log spectrum.vi  ?
Message 14 of 15
(1,514 Views)
I don't understand the question.
Do you mean that you want to change the integration time and then want to read the new spectrum?
That is exactly what you need to do. So first set new integration time and then read the spectrum again.
But one more warning: the first measurement after such a change in integration time can be measured with the old intgration time.
Fundamentally you should read an extra measurement after chaging the integration time !
Message 15 of 15
(1,503 Views)
