How to solve the problem of the conflict between“NI-VISA” and “IO library”
 HI
      when i install NI-VISA RUNTIME , My VISA program can't connection instrument.
     when i install IO library , When running NI I/O Trace I get the error "visa32.dll is not built for NI I/O Trace.
    How to solve it?
(3,332 Views)
I'm puzzled that the function should be the same, though the source of visa32.dll is different.
this is  my Declare:
 Declare Function viOpenDefaultRM Lib "VISA32.DLL" (ByRef sesn As Integer) As Integer
 Declare Function viOpen Lib "VISA32.DLL" (ByVal sesn As Integer, ByVal viDesc As String, ByVal mode As Integer, ByVal timeout As Integer, ByRef vi As Integer) As Integer
  Declare Function viVPrintf Lib "VISA32.DLL" (ByVal vi As Integer, ByVal writeFmt As String, ByRef params As Integer) As Integer
Declare Function viVScanf Lib "VISA32.DLL" (ByVal vi As Integer, ByVal readFmt As String, ByRef params As String) As Integer
 Declare Function viClose Lib "VISA32.DLL" (ByVal vi As Integer) As Integer
Why can't be used in NI_VISA. NI_VISAshould be more standard
(3,306 Views)
 A new discovery is that under condition NI-VISA mode , I can connect through TCPIP, but I can't connect through GPIB.
 PS: The linker I used is GPIB to USB.
(3,299 Views)
Hey I noticed you said you installed NI VISA Runtime, which is different than the actual NI VISA drivers. Have you tried downloading and installing the VISA drivers from the link below?
http://www.ni.com/download/ni-visa-17.0/6646/en/
Applications Engineering
(3,288 Views)
I installed NI_VISA 17.5
(3,277 Views)
