How to start NI-VISA Driver Development Wizard
Im now reading this manual:
http://zone.ni.com/devzone/cda/tut/p/id/4478
 i have labview8.6 on this pc, and i installed NI-VISA 4.6... as the manual says:
1. To open the DDW, select Start»Programs»National Instruments»VISA»VISA Driver Developer Wizard.
but the thing is, in the menu VISA, there is just documentation... there is no VISA Driver Developer Wizard... however i did install NI-VISA 4.6... any ideas?
Message 1 of 10
(18,756 Views)
My first hunch is that not all the components of NI-VISA were installed correctly. Try running the VISA 4.6 installer again and pay particular attention to this page. Be sure that the Driver Development feature is set to install.
Good luck!
Peter Flores
Message 2 of 10
(18,731 Views)
of course i did that!
i installed everything in that list! and after installation there was VISA meny in Start->national instruments, but there was no anything else in that menu except documentation!!
any ideas?
I am very new to LabVIEW but i begin to hate it! The only reason i began learning labview is because people working on some project use it (for some unknown reason...since everything could be done in C, even though its longer). The documentation is poor the software is buggy and everything is not straightforward! Robot Mad
ok...so any ideas about the problem? thanks anyway
Message 3 of 10
(18,725 Views)
On my pc (win xp), the path is "C:\Program Files\IVI Foundation\VISA\WinNT\NIvisa\NI-VISA Driver Wizard.exe". Do you have anything there? What OS are you using and are you logged in as admin?
Message 4 of 10
(18,715 Views)
well there is such a folder in my PC, but i dont have wizard executable!
and yes its im admin cuz its my PC.
i have the following files:
 niLxiDiscovery.exe
 PassportRegEdit.exe
 NiVisaCom.dll
 Readme.html
and USB and VXI folders....
so thats just it... any ideas?
Message 5 of 10
(18,694 Views)
i tried to uninstall/install again...no luck!! damn! any ideas? i wonder why is it like that...
i also tried to search docs online and other forums etc...for installation instructions...there seems nothing special about it, but for some reason its not working!!
Message 6 of 10
(18,693 Views)
cyrax,
As Peter pointed out earlier, there appears to be some problem with the "Driver Development" sub-component. Without access to your machine, I can't say exactly what happened there, but this is not a typical user experience.
In order to figure out the root cause, a first step might be to look at the installer log. If you installed the latest VISA, it should generate a log, as described in the KB below. If you could upload the summary log and the detailed one corresponding to VISA installation, that would be very helpful.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8KKSA0&l=en-US
Song Du
Systems Software
National Instruments R&D
Message 7 of 10
(18,682 Views)
BODY{font:x-small 'Verdana';margin-right:1.5em} .c{cursor:hand} .b{color:red;font-family:'Courier New';font-weight:bold;text-decoration:none} .e{margin-left:1em;text-indent:-1em;margin-right:1em} .k{margin-left:1em;text-indent:-1em;margin-right:1em} .t{color:#990000} .xt{color:#990099} .ns{color:red} .dt{color:green} .m{color:blue} .tx{font-weight:bold} .db{text-indent:0px;margin-left:1em;margin-top:0px;margin-bottom:0px;padding-left:.3em;border-left:1px solid #CCCCCC;font:small Courier} .di{font:small Courier} .d{color:blue} .pi{color:blue} .cb{text-indent:0px;margin-left:1em;margin-top:0px;margin-bottom:0px;padding-left:.3em;font:small Courier;color:#888888} .ci{font:small Courier;color:#888888} PRE{margin:0px;display:inline}
 Here goes the summary:
<?xml version="1.0" encoding="UTF-16" standalone="no" ?> - <summary> - <installEvent eventType="install" returnCode="3010" timeStamp="Sat Aug 22 20:33:27 2009" version="1.0"> <distribution>LabVIEW 8.6</distribution> <fileName>1859020927 - LabVIEW 8.6.xml</fileName> </installEvent> - <installEvent eventType="install" returnCode="3010" timeStamp="Sat Dec 12 17:40:07 2009" version="1.0"> <distribution>NI-VISA 4.6 Runtime</distribution> <fileName>1970991608 - NI-VISA 4.6 Runtime.xml</fileName> </installEvent> - <installEvent eventType="install" returnCode="-1" timeStamp="Sat Dec 12 19:50:58 2009" version="1.0"> <distribution>NI-VISA 4.6 Runtime</distribution> <fileName>1971012658 - NI-VISA 4.6 Runtime.xml</fileName> </installEvent> - <installEvent eventType="install" returnCode="-1" timeStamp="Mon Dec 14 20:40:05 2009" version="1.0"> <distribution>NI-VISA 4.6 Runtime</distribution> <fileName>1973021605 - NI-VISA 4.6 Runtime.xml</fileName> </installEvent> - <installEvent eventType="install" returnCode="0" timeStamp="Mon Dec 14 20:43:22 2009" version="1.0"> <distribution>NI-VISA 4.6 Runtime</distribution> <fileName>1973021922 - NI-VISA 4.6 Runtime.xml</fileName> </installEvent> </summary>
NI visa 4.6 runtime:
<?xml version="1.0" encoding="UTF-16" standalone="no" ?> - <installDetails version="1.0"> - <nidist.id> - <VolumeId> <DistributionGUID>{98EFA507-DC71-41BF-8D31-C9175648191E}</DistributionGUID> <DistPackageGUID>{35AD63AE-7905-4025-ADED-6A2FA9B62B3E}</DistPackageGUID> <DistributionVersion>4.6.0.30</DistributionVersion> <DistributionType>Driver</DistributionType> <DistributionLanguage>9,17</DistributionLanguage> <Volume>1</Volume> <ExePath>setup.exe</ExePath> <UpdateInfoFile /> </VolumeId> </nidist.id> - <timeStamps> <start>Mon Dec 14 20:43:22 2009</start> <initializationEnd>Mon Dec 14 20:43:24 2009</initializationEnd> <end>Mon Dec 14 20:43:55 2009</end> </timeStamps> <path>C:\National Instruments Downloads\NI-VISA Runtime\4.6\</path> <distributionType>NI</distributionType> <launchedBy>User</launchedBy> - <features> - <feature key="VisaSharedComponents32.VSAR02" name="VISA Shared Components 32-Bit fake feature"> <oldState>absent</oldState> <newState>local</newState> </feature> </features> - <customExecute> - <customExecute name="Uninstaller Update Utility"> <commandLine>"C:\Program Files\National Instruments\Shared\NIUninstaller\uninst.exe" /NIARP Show</commandLine> <returnCode>0</returnCode> </customExecute> </customExecute> <returnCode>0</returnCode> </installDetails>
so any ideas?
Message 8 of 10
(18,676 Views)
Accepted by topic author cyrax
That actually explains the problem. You are installing VISA runtime. If you start the installer again, you will see that the features tree looks different than the one Peter posted.
The component you need, Driver Development Wizard, is in the full VISA distribution, which you can download from the link below. The runtime is typically intended for deployed application. The development tools are absent from runtime and are only found in the full distribution.
https://www.ni.com/en/support/downloads/drivers/download.ni-visa.html
Song Du
Systems Software
Message 9 of 10
(18,672 Views)
yes got it, thank u. there were no manuals really telling abt such an installing process.
Message 10 of 10
(18,662 Views)
