How to transmit serial data with NI 8431 card with a fixed time interval between two frames
I'm trying to transmit serial data with NI 8431 card using custom device in veristand, I found there were some time gaps between the data sets transferred. After that I tried using simple LabVIEW code example with timed structure configured with required period, even though I'm facing the same issue.
Please help in resolving this issue.
Thanks in advance.
Message 1 of 1
(2,480 Views)
