How to use LabView 7.0 to control a furnace via serial port?
I am a very brand new user of LabView and I need to control my furnace, which has an Eurotherm 847 controller that uses a serial port. I downloaded the drivers for the Eurotherm, but I don't know how to configure them in LabView and how to use them for the control.Could anyone halp me with this task? Thanks.
(3,767 Views)
Most drivers come with a "Getting Started" example program. I took a look at that driver and it's equivalent for the Getting started vi is a vi called Eurotherm 808 Demo, which should work for you. If you have questions with using LabVIEW itself, you many wna to investigate NI Instructor led courses, interactive learning CDs, or web courses. For more details go here and click on "Call Me Now!"
(3,767 Views)
Ray K,
Thanks for the tip. I had a look on the demo and, after some small modifications, it will fit perfectly my needs.
acr
(3,767 Views)
