How to wrap IVI COM over IVI C?
thanks for ur response
                  Since C is Very old we thought of using COM for our solution,but some instruments are lacking IVI-COM driver support
can u please suggest me some other method for using IVI-C driver as like COM Drivers, since we need to expose common API''S
for all Drivers (Both IVI-COM and IVI-C),
What kind of wrapper can we create in common for both IVI-COM and IVI-C so that end user may not aware of underlying Driver?
thanks
Bharathi
Message 11 of 15
(1,751 Views)
Assuming you use IVI-COM and IVI-C drivers in mixture, the simplest solution is write language-based wrappers, that are all common style wrapping your IVI-COM and IVI-C.  For example (assuming you use VC++), you can write CIviDriver abstract class with InitWithOptions() and Close() and some other necessary methods and data members that can be applied to all the drivers. Then write model-specific wrapper classes such as CYourInstr class, which is derived from CIviDriver, then add model-specific wrapper methods.  This approach can be used not only for C++, but C# and VB.NET can also be okay.  By this approach, your app will be able to handle all the drivers as a collection or array of multiple CIviDriver instances.
Or, other way is write a "pseudo" IVI-COM thin wrapper DLL for the IVI-C.  (Applicable only if you have skill to write ATL COM DLL with VC++.)  Although this COM DLL is ***not fully*** complant with IVI-COM spec, you can treat it as if it was a true IVI-COM driver.  Actually, create an ATL COM DLL project, then add a component class such as CYourInstr with IYourInstr interface (IDL is auto-generated).  Add import directive to IDL and #import to stdafx.h to import typilib part from "IviDriverTypeLib.DLL"  Then hand-edit the IDL so that your IYourInstr interface is derived from IIviDriver rather than IUnknwon.  Hand-edit the C++'s CYourInstr class header and add IIviDriver, IIviDriver, IIviDriverUtility, IIviDriverIdentity, IIviDriverOperation as its base interface classes being inherited.  Finally you will have to add 10 ~ 20 additional method (of IIviXXXX interfaces that you added)  to build the DLL without compile error.  Actual implementation of the DLL will be probably redirection code to the IVI-C driver.   By this approach, all the drivers can be handled as a collection or array of IIviDriverPtr (smart ptr of C++) objects.
Message 12 of 15
(1,744 Views)
shall i use NI-Mesurment studio for genrating the language base wrapper?
thanks
bharathi
Message 13 of 15
(1,739 Views)
Hello Gagi,
I'd like to use IVI specific driver for "Chroma 61602" power supply and "TDS 2004B" oscilloscope.
I have installed "Microsoft Visual Studio 2005" and created a project in C#.
I followed the manual "Using IVI Specific Drivers in Visual Basic .NET, Visual C# or Visual Basic 6 Applications".
Step 1: OK,
Step 2: OK,
Step 3: I have no "Categories pane", just a list of all possibilities
Step 4: I have no "Instrument driver" option 😞
This is what I get when I go to Menu-->Project--> Add new item: (see Picture1.jpg in attachment)
I would be grateful for any hints 🙂
                           Glidko.
Message 14 of 15
(1,571 Views)
hi,
Hope installing NI-Measurment Studio will solve ur problem
Refer the attachment
thanks
bharathi
Message 15 of 15
(1,564 Views)
