Hp3458a storing samples
hi.
I'm sampling input voltage using hp3458a.
i see those samples on hp3458a displey with .vi attached.
my question is:how can i store them in spredsheet or otherwise?
Message 1 of 9
(5,548 Views)
Sorry can't open your vi... still on 8.6.1.
If you have an array of values, you can feed them into the file vis. Seen the examples provided in Fundamentals - File Input and Output ?
Don't know if you did, but there are ready made driver vi's for the 3458 here at the ni-site, browse the driver network.
Greetings from Germany
Henrik
LV since v3.1
Message 2 of 9
(5,529 Views)
       Here is the Model Page for the 3458A, where you can see that you have a couple of different instrument drivers to choose from.  If you are using a supported version of LabVIEW, I recommend that you use the LabVIEW Plug and Play (project-style) instrument driver that is both NI-Certified and NI-supported.
Cheers,
NathanT
Message 3 of 9
(5,524 Views)
And to save the data, you can use any number of file functions. Anything from 'Write to Text File' to the 'Express Write to Measurement File' can be used and all have examples for you to look at. Have you tried anything at all?
Message 4 of 9
(5,514 Views)
Hi.
Well, it's not so easy to implement as file input and output.
I've attached 3 pictures of previously attached .vi.
First picture shows triggering of hp3458a. He's taking samples now. These samples I see on instrument displey. I want to store them before I take statistic (mean and standard deviation) shown in 3th picture.
Second picture I've inserted, beacuse I want to wait exact time while sampling. This part, I think, is not necessary.
Message 5 of 9
(5,508 Views)
Accepted by topic author Tina2
The only measurement you have in your program is the standard deviation and the mean. If you want to get different or additional data, you have to modify the current query or add a new one. Have you tried the driver mentioned earlier?
Message 6 of 9
(5,498 Views)
If you want exact timing use the 3458 internal timer.
Henrik
LV since v3.1
Message 7 of 9
(5,466 Views)
Hi Dennis.
Can you help me with modifying query?
I tried, but with no success,
Can you explain in steps what should I do?
Thanx in advance.
Message 8 of 9
(5,452 Views)
What you should do is download one of the drivers mentioned above. If you use the project style driver, you will have a couple of examples (Help>Find Examples>Hardware Input and Output>Instrument Drivers>LabVIEW Plug and Play). One of the functions in the driver is Read Measurement. This can be used for single or multiple point reads.
Message 9 of 9
(5,432 Views)
