I/O Trace to LabView code
Hi everyone.
I would like to know in your experience, wich is the most effective way of going from I/O Trace recorded data to LabView code.
I´m trying to use commands that I recorded with a VI but they don´t work at all. I´ve tryed with the Visa and GPIB subVI´s.
Has somebody done that?
Greetings.
(3,905 Views)
(3,845 Views)
Thanks so much for the answer, the article is very interesting but I think there was a misunderstood.
What I´m looking for is a way of "translate" instruction recordeds with NI I/O Trace into LabView code. Have you done something like that?
Thanks from now.
Regards.
(3,842 Views)
Can you send a log to study what is possible? Including your vi's to try?
greetings from the Netherlands
(3,823 Views)
For sure.
Attached below, there is one of the files I´ve logged with I/O trace. The problem is that when I send the "EC" identification command, the instrument doesn´t answer until I send the command again.
PS: The PDF and I/O trace files are the same, just in case.
Thanks for everything.
(3,807 Views)
