I Want to Capture Waveform from Agilent Scope using GPIB interface: with VISA
19035i546964E9BFDBCC5CHi,
For my application i have to capture the graph waveform from AGILENT Oscilloscope DSO6032A using GPIB - USB interface.i don't want to use Express Instrument I/O Device. Instead of that i have to use VISA Configuration i can give the command throught Write VISA and Read the data from Read VISA.
For the command as :wav:data? it'll give capture the waveform from Scope i wanna display in GRAPH in Front Panel.
N. Srinivasan
(4,801 Views)
You should convert output from VISA READ to interger( use convert function in String tool).
(4,797 Views)
No.
srinivasan.accent@gmail.com wrote:Hi,
You should really be using the driver. Ask for it to be downconverted.
The conversion process is a bit complicated. If you want to use the binary format, look at how it is done in the driver. Image below.
(4,787 Views)
        I highly recommend that you use the existing LabVIEW Instrument Driver for your instrument
Cheers,
NathanT
(4,784 Views)
