I am looking for Siemens ULTRAMAT/OXYMAT 6E drivers or ASCII codes.
I am trying to Talk to Siemens Oxymat 6e with Labview 2009, i cannot find any drivers that are available or the manual for programming. Has anyone been here before?
(4,223 Views)
Hi ERM,
I took a look at the User Manual and couldn't find any specifics on the serial commands to get data from the device. Looking at the connection type though it seems like it is a RS-485 Serial connection. So you could communicate with it using a serial driver and VISA. As for the command set perhaps contacting Siemens would yield more results.
Hope this helps!
Chris T.
(4,181 Views)
I will contact Siemens.
Ed moneta
(4,116 Views)
I can send you the ELAN (Economical Local Area Netwok) manual for the RS-485 serial port connection to Ultramat6/23/, Oxymat 6
edward.rossino@siemens.com
(3,851 Views)
