I am looking for an GPIB/HPIB to parallel convertor
I need to print directly from my HP54501A scope?
(3,218 Views)
National Instruments does not have any hardware that will let you connect your scope directly to your printer.
The closest we have is the GPIB-1284CT, which is a Parallel-to-GPIB converter. It lets your computer talk to a GPIB instrument via your Parallel port. However, you will need to install our drivers on your computer to do this.
Another option for you is to get a printer with a GPIB port. Then you can connect it directly to your Scope.
Jack J.
(3,218 Views)
