I am looking for an oscilloscope with a Labview 7.2 version GPIB driver.
Any suggestions for a relatively low cost oscilloscope with a Labview 7.2 compatible driver?  Interface is probably going to be GPIB.
(5,711 Views)
Really not enough information. What is relatively low cost? How many channels? What sample rate?
There is no such thing as LabVIEW 7.2 and while the availability of a driver is one consideration, don't let the lack of one be a deal breaker in choosing the best instrument that fits your needs. A driver can always be written. It is not that difficult.
(5,710 Views)
thanksfor reply.  2 channel is fine.  1 GS/s sampling rate is adequate as is 50 MHz bandwidth.  I'm trying to stay under $2000.  LV version 7.1.
(5,703 Views)
What about the TBS1000 line from Tek?
Drivers are available but not for your very old version. You would have to have a driver down converted. The link to that is at the top of the page.
(5,698 Views)
I am also a fan of the TDS lineup by Tektronix.  Again, the drivers will likely need downconverted for you.  But if you are making a new system, I would highly recommend updating your version of LabVIEW.
(5,693 Views)
thank you both.  I think I have enough to go on.
(5,688 Views)
To be fair, Agilent, Fluke, Keithley should be looked at as well.
(5,683 Views)
