I am looking for drivers of Thermo Oriel Monochromator Driver 20050
The 20050 Monocromator Driver may be controller by a
computer eqquiped with rs-232 or IEEE-488 interface.I want to control a stepper motor with the 20050 via GPIB using Labview.I only have a poor and very old
program in C Language provided by Oriel, but I need
a Labview driver.Where can I find it?
(3,598 Views)
Hi Zazpi,
Unfortunately, I was unable to locate a driver for your instrument at www.ni.com/idnet. I looked at their site (www.oriel.com) and noticed that they appear to develop their own drivers. Your best bet would be to contact them about obtaining a LabVIEW driver. Oinre thy make the instrument, they would b the best situated to develop the driver! I would also like you to submit a request for this driver at: http://zone.ni.com/idnet97.nsf/instrumentdriverrequest/. We develop drivers based on demand and popularity so the more requests we have for it, the greater the possibility that we will develop one.
If you would like to try developing your own instrument driver (or modify the existing one), we have documentation, model instrument drivers, and driver templates to help at :
http://www.ni.com/devzone/idnet/development.htm
We also have a syndicate of third party vendors that specialize in National Instruments' products and services. Some of the vendors specialize in driver development. I would suggest contacting one of the Alliance members at:
http://www.ni.com/alliance
An instrument driver is a collection of functions that implement the commands necessary to perform the instrument�s operations. In short, someone read the instrument user manual and implemented some of the functionality in a program for the end user. Instrument drivers are not necessary to use your instrument. They are merely time savers to help you develop your project so you do not need to study the manual before writing a program.
There are example VI's in LV on Instrument Connectivity. If you go to the Help menu >> Examples.. >> I/O, you will see a couple and Examples.. >> Fundamentals for File and String manipulation. I would suggest tweaking them to suit your application. Also the specific command that your instrument responds to can be found from it's manual.
Some useful resources for your application are
ni.com > NI Developer Zone > Development Library > Instrument Connectivity
http://search.ni.com/?col=alldocs&layout=TechResources&ql=a , to search examples and knowledge bases
Hope this helps!
Best Regards,
Aaron K.
Aplication Engineer
(3,598 Views)
