I am not able to do voltage/temperature measurements using keithley 2700 and 7705. I am using labview 8.6 and NI-GPIB-USB-HS connector.
I am using following hardwares and softwares,
NI-GPIB_USB-HS connector ( IEE 488.2)
Keithley-2700 Multimeter/DAQ
Keithley -7705 swithing card
Driver software supplied by Keithley
K-type thermocouple
LabView 8.6
As I am new to Lab-View, I am not able to make it out how to do correct measurements. Can any one suggest me how to make voltage/temperature measurements.
(4,463 Views)
Select Help> Find Instrument Drivers and install the driver from NI. It comes with an example (Help> Find Examples). If you have problems, you need to provide details such as the error code/message.
(4,457 Views)
