I am running DOS version 2.7.2 for AT-GPIB/TNT. I have errors with ibdiag and ibtest .
I have a AT-GPIB/TNT board on my computer. I am using the NI488.2 software for DOS. I am running this on a Windows 95 platform in DOS.
Right now I am checking the software to test the hardware and the software. When I run ibdiag it first detects one board and then I get errors saying :
1. Make sure the GPIB cables are disconnected.
2. The base address does not match the address in the ni-pnp.ini file.
3. Another board or device is using the same address space. Try using a different I/O address and run the hardware diagnostic program.
For error # 1 I ensured that GPIB cables are disconnected. I dont' know what to do about error # 2 and 3. I have been
using the same software and the board in the previous machine which was DOS based and it gave me no problems. I have only one board in the machine. I tried changing the base address in the ibconf utility also but it didnt' help.
When I try to run ibtest it hangs in between .
ni-pnp.exe is running without any problems.
gpibinfo is also running without any problems.
With this info please let me know where the error could be .
(3,585 Views)
Install NI-488.2M software for Win95. As I remember there must be
a switch (checkbox) in the Control Panel | System | Gpib, which
will enable DOS support in the virtual DOS machine.
eb
"Amit" wrote in message
news:506500000008000000C11E0000-986697009000@quiq.com...
> errors saying :
> a diff
> know what to do about error # 2 and 3. I have been using the same
> help.
(3,585 Views)
