I am trying to collect a hardcopy from a Tektronix TDS 220 oscilloscope using GPIB and Labview.
I am trying to collect a hardcopy from a Tektronix TDS 220 oscilloscope. I am using GPIB through Labview. I have checked the Tektronix website and I have also browsed the support forums here, but I am stuck. The oscilloscope sends a BMP file over the GPIB, but I am having trouble receiving the file in Labview. Somebody said to use the IBRDF command, but I am not familiar with how one would use this command in Labview. Any help would be appreciated. Thanks.
Eric
(4,485 Views)
This only FYI.
when GPIB gets the hardcopy, there might be Oscilloscope command that tell LabVIEW to store the BMP file to somewhere in your machine. I am not sure LabVIEW can read and present the BMP file. I did not use file I/O before. You can eather check those file I/O functions or you find the file stored in your machine and open it with other SW such as PP MS Photo editor etc.
(4,485 Views)
"eric" wrote in message
news:5065000000080000005E160000-983677784000@quiq.com...
> Eric
I've found the VISA driver works OK without having to go to low-level GPIB
commands. Try the 'Getting Started 2.vi'
ftp://ftp.ni.com/support/instr_drivers/labview/windows/current/library/gpib/
tktds
2xx.zip
Good luck
Keith Fuller
(4,484 Views)
