I cannot find "scan for instrument​" at MAX
Hi~ :smileyhappy:
I connected GPIB-USB-HS cable between the laptop and Keithley 2602 device.
In MAX, I could find GPIB-USB-HS "USB0::0x3923::0x709B::016F05B4::RAW" under "device&interface"
However, I cannot find "scan for instrument" anywhere!
So, I coudn't connect equipment with laptop......
What is the problem??
(I use Window 7, and I installed NI driver.)
(3,822 Views)
did you install VISA?
and the usb gpib should be listed as gpib device under devices not as raw
greetings from the Netherlands
(3,813 Views)
Thank you for answer!!
I installed VISA 5.1.2.
But, I think it's not working well, cause VISA program(ex.driver wizard) is shut down easily showing error.
Also, I can see "VISA warning"(viOpenDefaultRM returned 0x3FFF0077~~~) under devices & interfaces tab in MAX.
I don't know How to fix this situation. . . . T^T
-Sopie
(3,799 Views)
uninstall and reinstall VISA is your best option
(3,795 Views)
