I developed a LabVIE
W6.1 application on a laptop running Win2K. Hardware interface is GPIB-USB-A. The program works great. When I install the application on a comupter with any other kind of GPIB interface it does not work as well. I get timeouts and other strange behavior.The problem area is the VISA Wait on Event Async.VI It timesout. Are there some setting that I need to change on the none USB GPIB interfaces.
(3,318 Views)
W6.1 application on a laptop running Win2K. Hardware interface is GPIB-USB-A. The program works great. When I install the application on a comupter with any other kind of GPIB interface it does not work as well. I get timeouts and other strange behavior.If you are using different GPIB devices make sure the addresses are the same. Make sure the same GPIB interface ID is being used(ie GPIB0). What other interfaces have you tried? If the other interface happens to be the GPIB-232CV-A you should be know that particular interface does not assert the EOI line. What event are you waiting on? It would also be very helpful to run NI-SPY to see what commands are being sent.
Ray K
NI Applications Engineer
(3,318 Views)
