I have problems with pci-gpib card under windows me, What I need to know what to do in order to fix this problems?
Hi, I have installed a pci-gpib card in my computer, I have a problem with
installation, the message of troubleshooting wizard is as follow:
"One or more missing GPIB interfaces.
There are several reasons why you might encounter this problem:
Reason: Your GPIB interface is incorrectly installed.
Solution: Please verify that your GPIB interface is correctly installed
and rerun the NI-488.2 Troubleshooting Wizard.
Reason: You are using a non-Plug-and-Play interface (e.g., AT-GPIB/TNT,
GPIB-PCII/IIA, GPIB-ENET) and you did not use the Add New Hardware Wizard
to add the interface to your system properly.
Solution: Click th
e Add Hardware button and the Add GPIB Hardware wizard
will guide you through the process of adding GPIB hardware.
Reason: For the GPIB-USB and GPIB-1394, the host controller (USB or 1394)
must be working properly in order to use the GPIB interface.
Solution: Click on the System Details button for details about the USB and
1394 host controllers.
Reason: For the PCMCIA-GPIB and PCMCIA-GPIB+, the PCMCIA host controller
Solution: Use the Windows Device Manager to verify that your PCMCIA host
controller is functioning correctly. Start the control panel by selecting
"Start>>Settings>>Control Panel", open the System icon and select the
Device Manager page. If you select "View devices by type", you can look at
the PCMCIA socket properties to ensure it is correctly enabled."
And on system details the message is the next:
"USB Driver type: USB universal host controller"
"This version of windows does not su
pport IEEE 1394."
I am using Windows Me, so i want to know what i need to do to fix this
problems.
Best regards.
(3,562 Views)
If you have a PCI-GPIB card, you needn't worry about the USB port or whether or not Windows ME supports 1394. All you need in NI-488.2 version 1.70 from National Instruments. Install this driver and then insert your card. Windows should detect the card and find the proper driver.
If this did not happen in the proper sequence, look in the device manager and see if the card was installed as an "other device". If this happens, remove the card in the device manager and have windows redetect it. If this is not a solution, you may consider the ask an engineer page at www.ni.com/ask. Provide as many details as possible.
(3,562 Views)
See Kamuela's response on 9/5/01
(3,562 Views)
