I hope someon
e can help me with this. We have a new Tektronix TDS3052 digital phosphor oscilloscope. I would like to use Labview for data acquisition. I know that the Labview website has drivers but they are in C. Are there any Labivew vis available? Thanks in advance.
(3,551 Views)
e can help me with this. We have a new Tektronix TDS3052 digital phosphor oscilloscope. I would like to use Labview for data acquisition. I know that the Labview website has drivers but they are in C. Are there any Labivew vis available? Thanks in advance.If you goto http://zone.ni.com/idnet97.nsf/browse/ and search for 3052, you should have a link to an IVI driver. This is useable from the LabVIEW environment provided you have the proper versions of VISA and IVI installed on your system.
(3,551 Views)
e can help me with this. We have a new Tektronix TDS3052 digital phosphor oscilloscope. I would like to use Labview for data acquisition. I know that the Labview website has drivers but they are in C. Are there any Labivew vis available? Thanks in advance.I finally figured out how to obtain the Labview vis. Is there an example program for Labview. The only one I found was for Labwindows.
(3,551 Views)
e can help me with this. We have a new Tektronix TDS3052 digital phosphor oscilloscope. I would like to use Labview for data acquisition. I know that the Labview website has drivers but they are in C. Are there any Labivew vis available? Thanks in advance.Hello,
if the driver library you found is the same as the one in the driver collection that came with LabVIEW (tkds30xx.llb, if installed available from the Functions palette under "Instrument I/O/Instrument Drivers/Tektronix TDS30xx scopes"), it should contain an example application called "tkds30xx getting started.vi". This should show the way how to employ them.
Best regards
Kristian Laß
(3,551 Views)
