I tried to install AT-GPIB card to PC Window 98.
I just installed 488.2 for Dos/Win that included in the package AT-GPIB, but it causes my PC freeze. I tried to removed what I installed before by deleting directly AT-GPIB folder from C drive. Then I followed the procedure descriebed on NI web page (GPIB Installation Wizard):
- I downloaded atwin271.zip and I installed it
- I replaced the gpib-16.dll and gpib-32.dll files with those from the Compatibility Release. The error message display "File Copy operation failed-incorrect number of bytes written to disk - source file on destination disk may be corrupted - use chkDsk. Source:\GBIB-16.dll' Dest C:\Windows\System\GPIB.16.dll" while I tried to installed atwin271.zip. My questions are please tell me how to remov
e everything of GPIB that I installed before (it not displayed on "add & remove softwar") and how to correct the error.
When I tried to add new hardware (Control Panel) I got the error message:
"Setup cannot load the installer (GPIBI16.DLL) for the GPIB hardware being installed. Contact your hardware vendor for assistance." Another question is My test system run a program in C language on PC 386 with Dos environment. Now I tried to move the program and AT-GPIB to new PC with Window 98 operation system. Please tell me what is the best way to perform this task. Do I still use the program execute file of C language to new PC or I should run and combine a new execute file with the new PC system? Thanks
Anthony
(3,276 Views)
I think the following knowledge base article has the information you need:
http://pong.ni.com/public.nsf/websearch/862567530005F09C862566A3006B21CD?OpenDocument
DiegoF.
(3,276 Views)
