I would like to automate some tests using IBIC. Can I start w/script and stop it from a batchfile?
I WOULD LIKE TO RUN A BATCHFILE FOR TEST AUTOMATION. I NEED TO CONTROL IBIC OR USE GPIB COMMANDS IN SOME OTHER WAY. HOW CAN I DO THIS?
(3,781 Views)
IBIC has a command to execute a text file (script). You would use $ followed by the path of the text file.
The following Knowledge base article explains this command:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/cbf6b1eb7da1a5348625664100758bad?OpenDocument
Unfortunately, IBIC does not take command line arguments. This means that you would need to open IBIC and type $ file.txt to execute the script.
Hope this helps.
DiegoF.
National Instruments.
(3,781 Views)
Thanks for the help. I had found that answer already.
But I was hoping it did take command line args.
-Tim
(3,781 Views)
It has been a while, but I thought of a solution. The following article explains how:
http://ae.natinst.com/operations/ae/public.nsf/fca7838c4500dc10862567a100753500/ca26374b52bd76f786256c910080f834?OpenDocument
Hope this helps.
DiegoF.
(3,781 Views)
