I2C and SPI with PXIe-6363
our NI PXIe-1078 chassis houses a PXIe-6363 I/O card which has hardware timing capabilities as far as I know. Is it possible to communicate from this card to an I2C or SPI device directly from the chassis instead of using FPGA? The PXIe-6363 features multiple digital I/O ports and there is the palette:
"Connectivity"=>"I2C&SPI" which contains the I2C Configure.vi and the SPI Configure.vi. However both require FPGA functionality.
Thanks in advance
Lysandros
(3,598 Views)
Accepted by topic author Lysandros
Hello Lysandros,
unfortunately you will need an FPGA Device or an dedicaded I2C or SPI Device.
Best wishes
Work with NI Hard- and Software for about 15 years now.
Certified LabVIEW Developer & TestStand Developer/Architect
(3,572 Views)
