IBRD and reciving a empty string
Hi
I have a problem with a National instruments pci-gpib card at a nt-pc,We also use a visual basic program 6.0.with some software from ni version 1.7. Evryting is going oke if i ask a string from my divice exept when the string is emty.the divice is hanging and i need to reboot it. We use EOI and if we do it we get a time out at the ibrd commando.I did turn the time out from 1s to 30s this was not a solution.
I did also use the tool from Ni to communicate with the divice, its also going wrong there if the string i want to recive is empty.
I have no gpib analyser at this moment.
I know that ibrd is doing some byte count... but there
is noting to count??I get with ni spy ibsta:6 and count=0
Who knows a solution for this pr
oblem?
(5,113 Views)
This might help:
ibrd(Device, Buffer, 100);
if( ibsta & ERR ) GpibError("ibrd Error");
Buffer[ibcntl] = '\0';
Aromal Lilly
Columbus, OH
(5,063 Views)
Also try using
ibeos( Device, 0x140A);
if( ibsta & ERR ) GpibError("ibeos Error");
Aromal Lilly
Columbus, OH
(5,062 Views)
