*IDN?
I send *IDN? but don't get a response from the epuipment. I made sure that i was writing and reading through the serial port correctly by using a loop back test. (connecting pins 2 & 3). What am i doing wrong?
(3,973 Views)
are baudrate etc correct
did you try with hyperterminal and got an answer than sure the lines are ok
did you send crlf after the *IDN?
so the instrument sees the End Of Message that is standard in gpib but must be sent in rs232
Try to swap the wires on pin 2 and 3
we call rs232 the Regular Soldering 2->3->2 standard
are baudrate number of bits, etc correct
and sometimes the instrument looks on DTS or RTS to see if the other side is powered up.
success
greetings from the Netherlands
(3,950 Views)
what kind of instrument are you communicating to? Have you already cheked on the instrument programming manual that it accept that command? I mean there are some instruments that use for istance "ID?" or "IDN?" or anything else instead of "*IDN?".
Regards
CLD - Labview Certified Developer
(3,950 Views)
