IEC 625 and GPIB
I got a noise Generator which has an IEC 625 Bus. Actually it should be the same bus like GPIB. I am using NI-GPIB Card to communicate with my Noise Generator but unfortunately I got problems to find the instrument in MAX. When I activate "Scane for instruments" in MAX I get an Error "Instrument not found". When I run NI-Spy I can see the error which cant find any GPIB Device on GPIB Card.
What should I do to communicate with my device? I know IEC 625 is an old bus maybe I have to configure something on my GPIB Card or in LV. Can you please help me with this case?
Thank your for your support.
(4,733 Views)
Hi
You are right, it is the same bus, but has a different connector only. I have seen connectors with on one side iec625 and on the other side IEE488. It is not exactly a 1:1 connection because the iec625 has less pins, but enough pins.
I think that MAX would not recognize the instrument but with the right connector should see that an instrument is present.
good luck
greetings from the Netherlands
(4,725 Views)
