When I send a command string to my instrument from
LabView using the Send VI, the instrument displays
a communications error, but it successfully executes
the command. When I send the same command using
MAX, the instrument does not display the
communications error. What's the difference exactly?
Tried all the different Send VI modes.
Also ... tried employing the Send Setup VI, sending an
Interface Clear first, and using the 488.1 VI.
Same errors ... but MAX works fine.
Any advice???
