IKA Eurostar control-visc mixer driver for Labview 8.2
I've purchased a IKA Eurostar control-visc mixer and am trying to find a driver/ VI for it. Has anyone developed these for labview 8.2? or know where I might find one?
Thanks in advance.
Message 1 of 12
(6,927 Views)
Hi Giuseppe,
I can not find any sort of driver for this specific instrument. You will need to use NI-VISA to write a serial application yourself. What I have found out is that you need to use "space \r space \n" as the termination character.
Regards
JamesC
NIUK and Ireland
Message 2 of 12
(6,916 Views)
"What I have found out is that you need to use "space \r space \n" as the termination character."
Well done, it's written at the manual. 😉
Message 3 of 12
(6,313 Views)
Giuseppe999--
Did you ever write a VI to control the IKA Eurostar lab mixer? I recently purchased one also and am interested in controlling it with LabView.
Message 4 of 12
(6,087 Views)
Hi, yes I did in the end - it turned out to be very simple, we went on to build complete automated rigs with pumps, valves, mixers etc in labview (even a robot on another project). Drop me your email and if I can find it I'll get it across.
Message 5 of 12
(6,070 Views)
I purchased an IKA Power control visc P1 but can't find a good VISA to control the device with LabView. Can you help me with that? Besides, what are all the numbers I should write in the VISA control panel parameters?
Thank you, gerard
Message 6 of 12
(5,820 Views)
Thank you, gerard
Message 7 of 12
(5,819 Views)
I'm also trying to interface with the IKA RET, and am having trouble communicating to the device.
Where those of you that successfully connected to the IKA, did you use a standard serial cable or the proprietary cable made by IKA?
Message 8 of 12
(5,781 Views)
Hi!
I am really stuck and would need and greatly appriciate some help. I am also trying to connect my PC to the IKA Eurostar stirrer and I am having some problems. When trying to run my the VISA I get the message that the device is valid but can not be accessed. Have any of you had this problem and if so hoe have you solved it.
Does anyone have a VISA for this application. I really only want to be able to read the output signal.
regards /Suss
PS. The error message I get looks like this, if it is of any help.
Error -1073807246 occurred at Property Node (arg 1) in VISA Configure Serial Port (Instr).vi->stirrer.vi
Possible reason(s):
VISA:  (Hex 0xBFFF0072) The resource is valid, but VISA cannot currently access it.
Message 9 of 12
(5,738 Views)
Hi!!!
Sorry for my delay in replying. Unfortunately I didnt find any VI that worked for the stirrer. As i had to programm other things I just put the programming of the control-visc P1 from IKA on one side. Did you fix this problem? Do you have any VI that really works? I only need to change the rpm...
Thanks, gerard
Message 10 of 12
(5,734 Views)
