ISOLATED DRIVERS FOR GPIB-USB-HS+ AND USB-232
I'm in the process of migrating a legacy data acquisition system to a modernized hardware/software platform. As a stepping stone, I need to use NI GPIB-USB-HS and USB-232 devices. The driver download for both together is Almost 1.6 gigs. That's quite ridiculous for two simple communication devices. A standard prolific USB-RS232 converter is no more than 7mb, and that includes drivers for all releases of windows.
Is there a way to install ONLY the drivers I NEED for these two devices. If not directly, can I do a full installation of the driver package on my laptop, and then just copy out all the files I need? And place them in the proper directory so I don't need all this mess of crap I don't need. It's kinda crazy to me I can't just get a simple set of drivers for a device. Thanks for the help!
(3,504 Views)
Hey MCEddieD
You would need:
NI-VISA
NI-SERIAL
NI-488.2
http://search.ni.com/nisearch/app/main/p/ap/tech/lang/en/pg/1/sn/ssnav:drv/fil/phwebntpmdm:124819/
http://search.ni.com/nisearch/app/main/p/ap/tech/lang/en/pg/1/sn/ssnav:drv/fil/phwebntpmdm:120494/
http://www.ni.com/download/ni-visa-15.0.1/5693/en/
Just make sure the drivers version match compatibility with your characteristics.
-AndreaG
(3,471 Views)
The links point to the downloads for the Full distributions that include utilities, MAX, etc. If all you want are the drivers, the search needs to be for Runtime distributions.
A search for NI-488.2 Runtime: http://search.ni.com/nisearch/app/main/p/bot/no/ap/global/lang/en/pg/1/q/install%20ni-488.2%20runtim...
A search for Serial Runtime:http://search.ni.com/nisearch/app/main/p/bot/no/ap/global/lang/en/pg/1/q/serial%20runtime/
And if VISA is really needed, then http://search.ni.com/nisearch/app/main/p/bot/no/ap/global/lang/en/pg/1/q/visa%20runtime/
And as Andrea pointed out, "Just make sure the drivers version match compatibility with your characteristics."
Hope this information helps.
(3,457 Views)
