IT6322 Itech Programmable Power Supply
Hallo,
I have a IT6322 Programmable Power Supply from Itech and I would like to interface it with TestStand.
Do you know if a driver for this instrument exist?
Thank you for your help.
Message 1 of 9
(8,623 Views)
Did you try looking in the Developer Zone section and clicking on the "Instrument Drivers" link? That would take you to the Instrument Driver Network page where you can search the database of available drivers. There is no driver for that specific model. I don't see any drivers for Itech. This means you can either take an instrument driver for a similar power supply and modify to fit how the IT6322 works (i.e., changing the command strings), or you can write your own, which is not all that difficult. I would suggest starting here: http://zone.ni.com/devzone/cda/tut/p/id/4359
Message 2 of 9
(8,612 Views)
You also do not mention which programming language you are using. If you want to use the built-in IVI step, you would need to create an IVI-C, IVI-COM, or IVI-NET driver.
Message 3 of 9
(8,604 Views)
Accepted by topic author BenDem
Dear All,
Thank you for your answers.
I finally received the VI files from the Power Supply manufacturer.
Best regards
Message 4 of 9
(8,590 Views)
I would like to have it
thanks you
Message 5 of 9
(8,503 Views)
Hi Sir,
Good Day!
Can I request it from u? here's my email.
I have another request if u know the solution.. I need to program Itech Power supply
using Microsoft vb,c++ or c# but the problem is its hard to communicate with it since
the interface is RS232TTL type which is not typical for us.. Can u help me with this?
Thank and God Bless!
james
Message 6 of 9
(7,775 Views)
If it is still available, I would like to have a copy of the VI to control the Power Supply IT6322 .
Thank you in advance for your kindness,
Richard.
Message 7 of 9
(7,202 Views)
Can you pls share the same
C heqder file
dll file, or the LabVIEW files
Message 8 of 9
(6,867 Views)
Hi Sir,
If it is still available could you kindly share to my email.
Message 9 of 9
(1,985 Views)
