IVI 8901a polling, take 1.
Okies I tried the IVI version from NI/lecroy, and I
don't ssem to get the LAM/SQR work, the WaitSRQ either times out or never does it. I might be missing something important here, if so please point it out.
code
#include
#include "lc8901a.h"
#include "lc8901a.c"
#include
static ViStatus lcGPIBstat5[100];
static ViStatus lcGPIBstat4;
static ViStatus lcGPIBstat3;
static ViBoolean X;
static ViBoolean Q;
static ViSession lcGPIB;
static ViInt32 databajs[1024];
static ViInt32 fff;
static int pcGPIB;
//unsigned int MyRetn[1] = {0};
void init_pcGPIB(void);
//have LAM at 1024 words on 3512.
int main ()
long int fis;
int d,g,h,k=0;
short int apa=0,LAM[32];
lc8901a_init ("GPIB::2", 6, 1, &lcGPIB);
lc8901a_Mode(lcGPIB,2,1);
lc8901a_SetSRQ(lcGPIB,1);
lc8901a_WaitSRQ(lcGPIB,3000,LAM,&X,&Q);
// this line above gives General protection fault at 0167:6380235B
g=time(0)+10;
//if(LAM[16]==1){
if(LAM[17]==1){
h=time(0);
lc8901a_Read(lcGPIB, 2, 0, 17, 512,100,databajs,&X,&Q);
k++;
// if i use the WaitSRQ here, something about invalid value pops up.
fis = (int)databajs[1];
fis = fis & 8191;
printf ("%8.3f\n ", fis*.0009884);
printf ("%d\n ", k);
scanf("%d",&d);
lc8901a_close (lcGPIB);
return 0;
the init call I asked about couple of weeks ago havent found any good solutio to this. the "GPIB::2" is sent
erroneously.
------------------IBspy log-------------------
1. iblines(0, 0x20FF)
Process ID: 0xFFFDF163 Thread ID: 0xFFFCDA07
Start Time: 16:11:23.470 Call Duration: 00:00:00.270
ibsta: 0x100 iberr: 0 ibcntl: 0(0x0)
2. ibfind(GPIB0)
Start Time: 16:11:23.630 Call Duration: 00:00:00.110
3. ibsic(0)
Start Time: 16:11:23.740 Call Duration: 00:00:00.000
ibsta: 0x130 iberr: 0 ibcntl: 0(0x0)
4. ibsre(0, 1)
Start Time: 16:11:23.740 Call Duration: 00:00:00.060
5. ibdev(0, 2, 0 (0x0), T3s (12), 1, 0x100A)
Start Time: 16:11:23.800 Call Duration: 00:00:00.000
6. ThreadIbsta()
7. ibconfig(UD0, IbcREADDR (0x0006), 1 (0x1))
Start Time: 16:11:23.850 Call Duration: 00:00:00.000
8. ThreadIberr()
9. ibconfig(0, IbcEndBitIsNormal (0x001A), 0 (0x0))
Start Time: 16:11:23.910 Call Duration: 00:00:00.000
ibsta: 0x130 iberr: 1 ibcntl: 0(0x0)
10. ibln(0, 2, NO_SAD (0), TRUE (1))
ibsta: 0x130 iberr: 0 ibcntl: 1(0x1)
11. ibtmo(UD0, T10s (13))
Start Time: 16:11:23.910 Call Duration: 00:00:00.050
ibsta: 0x100 iberr: 12 ibcntl: 0(0x0)
> 12. ibdev(0, 4095, 0 (0x0), T10s (13), 1, 0x0000)
> Start Time: 16:11:23.960 Call Duration: 00:00:00.060
> ibsta: 0x8100 iberr: 4 ibcntl: 0(0x0)
> 13. ThreadIbsta()
> Start Time: 16:11:24.020 Call Duration: 00:00:00.000
> 14. ThreadIberr()
15. SetGpibStatusVariblesForThread(0x0100, 0, 0 (0x0))
Start Time: 16:11:24.020 Call Duration: 00:00:00.050
16. ibconfig(UD0, IbcREADDR (0x0006), 1 (0x1))
Start Time: 16:11:24.070 Call Duration: 00:00:00.000
ibsta: 0x100 iberr: 1 ibcntl: 0(0x0)
17. ibconfig(UD0, IbcUnAddr (0x001B), 1 (0x1))
Start Time: 16:11:24.130 Call Duration: 00:00:00.000
18. ibwrt(UD0, "j", 1 (0x1))
ibsta: 0x100 iberr: 0 ibcntl: 1(0x1)
19. ThreadIbcntl()
Start Time: 16:11:24.130 Call Duration: 00:00:00.050
20. ibconfig(UD0, IbcUnAddr (0x001B), 0 (0x0))
Start Time: 16:11:24.180 Call Duration: 00:00:00.000
ibsta: 0x100 iberr: 1 ibcntl: 1(0x1)
21. ibconfig(UD0, IbcUnAddr (0x001B), 1 (0x1))
Start Time: 16:11:24.180 Call Duration: 00:00:00.060
22. ibconfig(0, IbcAUTOPOLL (0x0007), 1 (0x1))
Start Time: 16:11:24.240 Call Duration: 00:00:00.000
ibsta: 0x130 iberr: 1 ibcntl: 2(0x2)
23. ibwait(UD0, 0x0000)
Start Time: 16:11:24.240 Call Duration: 00:00:00.050
24. ibwait(UD0, 0x0000)
Start Time: 16:11:24.290 Call Duration: 00:00:00.000
25. ibwrt(UD0, "A", 1 (0x1))
Start Time: 16:11:24.290 Call Duration: 00:00:00.060
26. ThreadIbcntl()
Start Time: 16:11:24.350 Call Duration: 00:00:00.050
27. ibconfig(UD0, IbcUnAddr (0x001B), 0 (0x0))
Start Time: 16:11:24.400 Call Duration: 00:00:00.990
ibsta: 0x900 iberr: 1 ibcntl: 1(0x1)
28. ibwait(UD0, 0x0000)
Start Time: 16:11:25.390 Call Duration: 00:00:00.060
29. ibconfig(UD0, IbcUnAddr (0x001B), 1 (0x1))
Start Time: 16:11:25.450 Call Duration: 00:00:00.000
ibsta: 0x900 iberr: 0 ibcntl: 1(0x1)
(3,621 Views)
Hello-
Line 12 of the Spy captures shows:
This means that PAD=0 and SAD=4095. It's unusual to use a PAD of zero since this is typically the primary address of the GPIB controller. It's also very unusual to use a SAD of something other than zero. It looks like the instrument driver may need updating.
Randy Solomonson
Application Engineer
(3,621 Views)
Allright, how long will that take?
the IVI of lc8901a makes easier
to tie the data to a GUI.
/Anders
(3,621 Views)
Hello-
IVI is a good alternative in this case.
Randy Solomonson
(3,621 Views)
